1 - 20 of 27 Posts
Downunder wonder
110 deg seems the standard for 4 valve heads but i know my 5valve are on 107
burnin' up the streets
it all depends on where you want your power to be concentrated.
if you want good all around power go with 105/105.
if you want top end go with 107/103
if you want low end go with 100/102
but you will want to check clearances if you are going to differ from stock 105/105
The One
Discussion Starter · #4 ·
Let me make sure I have this right 105/105 would be best for all around is that were they are stock?
The One
Discussion Starter · #6 ·
I drag race and the bike has now low end any ways you thank I sould go for upper end power or leave it at 105/105? Were do you have yours?
right now I'm back at stock settings but my bike makes so much power anyway I don't feel the need to mess with it anymore.
do you use low end when you're racing? I always launch at about 8 or 9 grand so I'm never at lowend.
Smokin Hot R1
BSR-1 what would u suggest for road racing the top end numbers ? clearance on both of the cams? which # is intake ? thank u
I would guess you'd want either mid 105/105 or top 107/103.
the first # is the intake cam.
I don't understand your question about clearance. valve clearance?
The One
Discussion Starter · #10 ·
I do leave around 8 also and once you get out of first you will always be in upper anyhow. I would like to say that I had alot of power also and I was going to have you do head work put last wed. night my best freind died in a bike wreck (see biker down) and I dont think my wife would like very much if I went and spent that kind of money to make bike faster. So until it cools down I am left with what I can sneek in like spliting head gasket maybe degree cams stacks and take it and get tuned.
Smokin Hot R1
u had said that u changed yours & then back to stock did u have to change the clearance's ? when i did my 2000 i think it was 100 / 102 & shim to the fat side of the tolerance . was just curious what u had done or would suggest just looking at all improvements that can be made to bike for the spring time / racing gasket / head porting / would i have to purchase new sprokets or machine stock one's / or just buy racing cam's 1700.00 or so? your imput is appreciated thank u in adance
gotcha, sorry about your friend.
I was experimenting with a lot of different things so I could learn for myself what works & what doesn't instead of going by just what I hear.
at one point I wasn't making the power I thought I should so I changed back to stock so I could take cam timing out of the equation.
since that time I've also gone -1+2 so that along with the 167HP & I've been pretty happy to just leave well enough alone.
actually I want to pull my motor one more time (that'll make 7 times I've had it apart in the last year) & put on my latest creation but I need some money to get a valve job & mill.
Smokin Hot R1
I could tell u where playing with it but that's cazy 6 times in one year i'm like 1 time for each bike I own here's a funny what do u torque your rear sprocket to lol
RIP biker down
RIP biker down
I think it's 27ftlbs?
I know it's wrong in the manual, I think it says 72lbs.
I just make them good & tight (that's an official term isn't it?).
Drop a gear and Disappear!
how much top end power would you gain by going to 107/103
I've done quite a bit of testing but I don't have a dyno so I haven't tested everything/every combination.
in general it will put more power at the top & take it away from the bottom.
you could ask chuck graves I'm sure he know a lot more than I do.
as a matter of fact he is who gave me the sugessted #'s for low end power.
1 - 20 of 27 Posts
