almost ready to take bike apart, buddy called to go to last drag race of year... so hooked all nitrous up for first time this year...sad i know.. brought 2 2 lb bottles and one 10 lb bottles.. idea was to load it up with nitrous or blow it up. first time with wide band and nitrous.. never knew where A/F was with wet kit. i know that at 60% in progressive box it made 71 hp. first pass A/F on button was 11:1... holy cow... didnt have any different fuel jets for nitrous.. so starting leaning on map. still be i could get in short time was 12:1 safe on bottle should be like 12.9:1 or so. surpised it even ran. it would kill motor as i lifted off throttle...from overly rich. at 62 inch WB is was yanking front wheel off ground leaving line, spinning on down track. times were never any good..but in 1/8 mile it did pick up 11 mph on nitrous from motor pass. i did purchase a kestral 4000 weather meter.. it gives all kinds of info.. temp, baro, wind speed, wet bulb, heat index, alititude and it even gives correct altitude.. so with some of nicest weather all year here.. altitude was 2850 and corrected DA was 4400 ft... god bike wont run worth crap at my own track. why it runs .4-.5 better at good track at sea level. temps were in mid 70s to high 60s. well it didnt get close to blowing up and ended up turning start percentage down and slowing down progressive to get it to hook up.
did make monstrous pass on zx14.. god it pisses me off the bottom end power of that thing. left at 7500 and thru clutch going for 1.30 60ft.. but ended up with 1.41 going on rear tire. front end was up @ 4 feet in air. but supposedly there is guy with few tricks for getting more bottom end that works with brock davidson and runs an R1. so gonna take it apart or winter and try other head again and see what i can come up with. but in end problem in 1/8 mile with my bike is no bottom end and 330 compared to zx14. owner of 14 ran me first time trial and with him on it we ran .02 of each other. hes little heavier and not as agressive on clutch. trying to get him to throw clutch harder. he is in high 1.50 in 60ft. didnt matter what i did to nitrous, even leaving line off of it with rpm window switch.. it wouldnt pick up in 3.30s like what 14 was running.
again 2 most important times in running 1/8 or 1/4.. is 60ft and 330ft. that dictates rest of run. oh well time to take it apart and check bearings and such. 4 years on motor now racing.. so see what it looks like this time.
