1 - 3 of 3 Posts
The K-tech fork tubes are wider in diameter at the clamping points than stock or Ohlins. Has anyone fitted up the KTR4 forks to an R1? If so, is there a triple that fits or did you have your smaller triples machined out to fit?
The upper tube is 52mm and the lower is 58mm on the KTR forks
I'm going to be a dad!
Youll need aftermarket clamps. Checkout EDR Performance they’ll have what you need.
  • Like
Reactions: brad8266
SuperbikeUnlimited.com
Evol Tech makes Supsrbike Clamps.
U Toob John McKown's channel. You can see his build with ktechs.
In fact...he is a member on here...Kmac i think
1 - 3 of 3 Posts
