1 - 3 of 3 Posts
VFX Running light FX kit - Programmable $45 shipped
Brand new never installed. Totaled my bike... :chair: Save a few dollars, and buy mine! ;)
Paypal preferred. Will only ship to verfied/confirmed address.
Thanks, Franky
Now you can show off those aftermarket signals/flushmounts all the time! Almost all aftermarket signals are not equipped with a running light wire which means the only time they light up is when you're signaling.
With the all new Running Light FX kit, not only can you add the running light feature to your aftermarket signals, but also control the intensity level to suit your ride (14 levels). Now add in mind blowing signal animations (17 animations) and you have the most advanced kit of it's kind on the market!
The Running Light FX kit is great for standalone front and/or rear signals - for rear signals simply set the running light intensity to Full OFF and take advantage of the signal animations!
Unlike other kits with a resistor based solution, the Running Light kit uses digital modulation that safely works on all types of standard aftermarket filament and/or LED signals. Users can even parallel multiple signals without affecting the running light intensity of each signal.
The ultra compact inline package allows for quick, discrete installation with onboard push buttons for easy programming.
Key Features:
14 different Running Light Intensities (incremental from Full OFF to Full ON) choose the one that suit the look of your ride!
17 trick Signal Animations (16 + bike default) >> check out the demonstrations
Discrete Inline Installation (3 wire in, 2 wire out)
Works on all types of standard aftermarket signals (LED and/or Filament)
Microprocessor based digital modulation technique (non-resistor based)
Solid State Electronics for safe long term, reliable operation
Fully encapsulated module for complete weather resistance
Ultra compact modules with push button switches for easy programming
Built-in DOT Flash Rate control - module can be calibrated to bike flash rate or DOT rate
User may stack multiple signals onto each module without affecting running light intensity (in parallel)
Reverse bias and current overload protected
Easy to follow installation manual with diagrams
Toll Free Technical Support
Application:
Ideal for all sport bikes, customs & other vehicles where riders would like to add Running Lights and/or Signal Animations to 2-wire signals (front and/or rear)
Great for varying the intensity of all 12VDC LED and/or filament lighting (up to 3 Amps)
1 - 3 of 3 Posts
