yep
most likey- back out the idle screws- just REMEMBER YOUR STARTING POINT.
Hoenstly, with the jet kit and just a slip on, you probably would be ok, but with the air filter getting more air in, most likely, you're running a bit lean. Remember, needles are repositionable with shims too- try a #4 on each one- start with 1 shim, not 2- with the jets, 2 shims could put you to the rich side
