1 - 9 of 9 Posts
just bought bike and tearing it down when I noticed this.
What cover is this and I unscrewed the big plug in the middle where it seems to be weeping out and there is no o-ring which seems odd which would probably stop the oil seepage. Does anyone know if there is suppose to be one?
Action figure sold separately
It's the oil pump cover, and yes, there is supposed to be an o ring. On the '00, it's part # 93210-32172-00 for $3.42 at Mr Cycles.
Discussion Starter · #4 ·
Yes it low speed slide on that side.
I need to replace the clutch cover as well is that hard to do looks like there is a seal on the bottom where the clutch cable goes in that has some leakage as well a bit.
Is the clutch cover hard to replace and slide on?
thanks for the help I will order an O ring.
oh yea its a 2002
Looks like you're also leaking from the buttonhead bolt just in front of the plug. There is a gasket for the buttonhead bolt, part # 90430-08143-00 for $2.12 from Mr Cycles.
Discussion Starter · #8 ·
No just oil and junk rolled up looks like a cut. Thanks for all the info I bought the parts tonight.
oh yea its a 2002
The clutch cover isn't very difficult, the hardest part is getting the actuator rod positioned properly with the actuator gear (connected to the external lever). The manual explains it I think. A little time fiddling with it and you'll see and figure it out. Otherwise not a big deal.
1 - 9 of 9 Posts
