1 - 3 of 3 Posts
I'm going to pull some compression numbers this weekend and wanted to know what I should be looking for on a 2001 R1 believe it's stock with thinner head gasket.
THE MAN
180-200
will be closer to 180 if you check cold.
my factory service manual for my 00 says 192 min 206 std and 213max
much more important that the actual high or low number you get though is that they are all very similar. if you get 180 on all 4 then you are good to go, if you get 210 on three and 180 on one you have a problem...
1 - 3 of 3 Posts
