1 - 11 of 11 Posts
Jaw Droppin' Stunts
sonic13 said:
i got a 2003 r1...how would you adjust the suspension so that wheelies are made easier and smoother? do you make the suspension hard or soft?
...nuttin'! ...get a steering dampener cause these bike are tank slap happy, and when your comin' down from a wheelie, for a softer landing, give it gas on the way down...:bandit
WHEELIE KING-girls luvmyweiner
I bounce mine up, and I've got my front set up soft ( I also have ohlins forks) and the rear set stiff, If you clutch them however, you may want the front a little stiffer. Hope this helps goodluck
you can try taking a flat blade, and "loosening" the adjusters on top of your forks. iirc, they are already 13 clicks from the tightest setting.. there is another 7-8 clicks of softness left. that will help you bounce it up, or with chopping the throttle.
be cautious though, with the diff. suspension the bike not behave like you're used to.
i run with mine stiffer up front for stoppies.. which initially hurt my ability to bring up 3rd and 4th.. but i got used to it.
Premium Member
Stiffen the whole bike up. Softening makes your forks travel up and down slower = no bounce.
The rear should be stiff cuz you don't want the suspension to travel while you're in a wheelie. This will just cause inconsistant wheelie hight and adjustments = a nervous wheelie.
For endos... it's different. But that wasn't your questions.. so I'll stop here.
What Was That?
woow, rear shock preload 5 from off helps me
keep the front standard except for comp 1 click harder, cable tie the fork tube and you will see if your bottoming out, and really it means nothin cause technique will get the bike up anyway,,,,,,,, good luck, getting it ups is easy controling and balancing is another, slack chain and half a tanks helps when your learning , don't take anythin for granted!!
1 - 11 of 11 Posts
