1 - 6 of 6 Posts
· Premium Member
I just put a Scotts damper on my 01 a couple days ago. I really haven't had a chance to ride it much with the damper on. I was wondering what kind of adjustments you guys have done. I really don't know where to start. I just ride my bike, no wheelies yet, not really hard but not just cruising around either - just to give you an idea of what I need out the damper. Any tips?
Thanks
· Premium Member
Discussion Starter · #4 ·
Yah, the manual gets a little confusing to me. I know I'll have to keep messing with it till I get it where I want it. Thought I would check to see if most people were using a similar setting.
Thanks
· 2003 R1 Silver
its been a while since i installed mine but the manual more or less just said to adjust it according to your liking...............given i probably didnt read it to in depth....but if you get it to tight you will notice trust me. Other than that adjust to what is most comfortable for you.
· Registered
OK,I feel I have to shim-in some more here... :lol
The manual basically tells you to never touch the knob under the plastic cap (high speed damping) but only tailor the slow speed damping to your likings;
One adjustment has an effect on the other!
But the slow speed adj. has less efefct on the high speed adj.;the contrary applies,the high speed adj. has a lot of effect on the slow speed adj.
Confused?
I was,had to read the booklet like 4 times to make sure.
1 - 6 of 6 Posts
