I'm trying to understand what a parts supplier / manufacture has told me, about their fuel caps. My question basically was: If I do a test as if bike is crashed, and turn the tank up-side down, I expect it not to leak (specifically fuel cap/ from under it).
The guy replied to me: (from a big brand producer)
"The only place the cap will leak is through the venting pipe.
Without the venting pipe the tank would vacuum and the engine would be starved of fuel."
So I'm irritated with myself, I don't understand how the venting pipe works, what he wrote, and what does that imply.
The venting pipe is the 'hole' in the tank, for the air to get in. So is he saying, not matter what, if you turn the tank on the side or upside down, it will leak through the venting hole?
The venting pipe is at the bottom of the R1's tank, no (fuel tank breather hose)? So if fuel is coming out, it will be dripping from that pipe.
What does this venting pipe has to do with the cap, what am I missing?
Please someone explain to me how it works. I don't want to get a wrong idea that a leaking fuel tank is Ok .. even if bike is on it's side. :eek5:
(all I know is, when I turn the tank over with the stock Yamaha OEM cap nothing freaking leaks from the tank, period)
:dunno
:dunno
