1 - 3 of 3 Posts
those who cant do teach...
what are slide stops , velocity stacks ?
wen talking about suspension tuning is , for example , "7 clicks out" meaning u are makin it hard or soft ?
i know on all suspension settings are turned clockwise to stiffen and counter-clickwise to soften but on an 02 R! does the rear preload work d other way ?
Administrator
Airbox Velocity Stacks 2002-2003 R1. Graves Motorsports Velocity Stack Kit for the 2002 YAMAHA R1. The kit mounts directly in the stock air box and is deigned to smooth out the power curve, increase horsepower thought and improve fuel efficiency. Power Gains: 5 horsepower midrange / 2 horsepower peak. These stacks can be used with aftermarket airboxes also.
http://www.tobefast.com/graves-r1-velocity-stacks-c-52099-p-1-pr-167.html
Throttle Slide Stop Kit has been designed to hold the throttle slides in the fully open position while increasing fuel pressure in the injectors fuel rail. The outcome is improved throttle response and increased acceleration. Must use Power Commander.
http://www.tobefast.com/graves-r1-slide-stop-kit-02-03-c-52099-p-1-pr-1705491.html
1 - 3 of 3 Posts
