1 - 7 of 7 Posts
Mustang Hater!
I'm getting ready to wrap my exhaust from the EXUP to the silp-ons with exhaust wrap, but I can't find the metal zipties that people suggest to use anywhere (I've checked Sears, Home Depot, OReilly's, and Autozone). So the question is: Will plastic zip ties withstand the heat? Keep in mind they are going on the outisde of the exhaust wrap, so temps should be lower than being wrapped directly against the exhaust. If worst comes to worst, I can always mount the wrap with the plastic ties now, order the metal ones off the internet, and switch them out next weekend.
Thanks for the input.
Action figure sold separately
Try it. If it doesn't work, just use a little safty wire till you get the metal zip ties. You could also use a hose clamp in the meantime.
you're kidding right?
Surface temps on wrap still get well above ambient, and it will be worse inside the plastics.
On a hot day, in traffic, you going to smell burning plastic and start to leave a trail of wrap behind you...
Get some safety wire and use that. Keep it within 5-6 inches of the next one and you'll be good.
:yesnod :yesnod
Home Depot or any hardware store: 1.00 each. If you want to save time and prevent making a mess just go with metal
Good Luck,
J.
Mustang Hater!
Discussion Starter · #5 ·
After thinking about it some more (and reading the responses) I'm just going to use safety wire. So what if it takes me a little longer, at least I'll know that it is going to stay.
Thanks guys.
see you at the races and ride
I used the black zips on my 05 when I wrapped the y and muffler inlets and they worked fine. No more hot seat either, I used the 1" black(gray) thermotec wrap from jegs.
Mustang Hater!
Discussion Starter · #7 ·
That is the exhaust wrap I have sitting in my garage, and I also have the exact same zipties as well. Seeing as I didn't get around to putting the wrap on tonight, I might go ahead and try out the zip ties.
1 - 7 of 7 Posts
