1 - 9 of 9 Posts
CSracing makes a really great under foot exhaust.
It takes 14lbs off the bike and it sounds so incredibly good.
I have been racing with it this year in CMRA and I am very Happy with it.
Discussion Starter #7
I bought the quick shifter you posted above. can I install before flash? it just wont work till flash correct?
Premium Member
The Dano’s Performance? Yes. You can install before flash but it won’t work if flashing hasn’t been enabled. But, having it installed without a flash will NOT harm anything. The bike will work as it normally will.
The cheapest route for leisurely riding is:
•ECU flash tune (the absolute best and most expensive is a full Dyno tune with on road/track tuning with a piggyback fuel module that has the ability to log/adjust AFRs)
•ECU enabled quick shift
•3/4 exhaust
Mods that I highly recommend:
•Graves Manual CCT
•Grave Clutch Kit fix
•Speed Cell or any other reputable lithium battery (a must have)
You have literally just purchased the most reliable thing on 2 wheels with an engine. It’s the most reliable generation R1 and possibly the most reliable bike built to date.
Most common issues:
•Automatic CCT failure
•Dying batteries (crossplane takes a lot to get started)
•Starter slowly dies over time around 15,000 to 20,000 miles mark (this heavily depends on if you keep a good strong battery installed)
Welcome to the forum.
1 - 9 of 9 Posts
