1 - 3 of 3 Posts
· Registered
Hi i dont know if i have done this right but been told the guys on here are very helpfull. I have a R1 1999 and riding home tonight i was having trouble getting it into gear.Dropping down to first gear it just kept clicking down down and down not engaging into 1st gear.The neutral light didnt come on then did.At the traffic lights its hard to engage a gear then finally i could select second and it changes up fine.Just changing down is the problem the gear shift sploin is fine its no slipping around its tight nothing is loose in the area either.Any help would be very greatfull ty.
· 14k+ posts and not one helpful
Hello, welcome to the forum first of all. I'm sure someone can help you out with the issue. I'd suggest you create a new topic in THIS section, or you could wait for a mod to move it. Either way you'll get an answer to your problem. Best of luck :)
1 - 3 of 3 Posts
