1 - 5 of 5 Posts
unleash the beast
98-99 R1
front axle pinch bolts: 17 ft lbs
front axle: 52 ft lbs
rear axle: 110 ft lbs
brake caliper bolts: 29 ft lbs
brake disc bolts (all): 13 ft lbs
rear sprocket bolts: 50 ft lbs
00-01 R1
brake calipers bolts: 29 ft lbs
02-03 R1
front axle pinch bolts: 13 ft lbs
front axle: 66 ft lbs
rear axle 108 ft lbs
front brake caliper: 29 ft lbs
rear brake caliper: 19.5 ft lbs
04-06 R1
FRONT AXLE PINCH BOLTS: 15 FT LBS
FRONT AXLE: 66 FT LBS
REAR AXLE: 108 FT LBS
BRAKE CALIPERS (FRONT): 25 FT LBS
BRAKE CALIPER (REAR): REAR BOLT: 16 FT LBS
FRONT BOLT: 20 FT LBS
MOUNTING BOLT: 12 FT LBS
07-08 R1
front axle pinch bolts: 15 ft lbs
brake calipers (front): 25 ft lbs
brake caliper (rear): Rear bolt: 16 ft lbs
front bolt: 20 ft lbs
mounting bolt: 12 ft lbs
unleash the beast
Discussion Starter #3 (Edited)
1 - 5 of 5 Posts
