Have'nt forgot about you, I made 3 calls to Brooklin Cycle today but the guy I deal with was'nt available for various reasons during those calls, Rob's a busy guy.
I also called my local Yam dealer to find out about the availability of the YEC gasket, their system would not locate the gasket # I gave them, so they are calling Yamaha Canada to inquire.
I have to find a permanent source for these things myself as the race team will be returning all of their previous years' R1's stock to make room for the new model.
As Martin has said Cometic would be a good place to look and I think I am going to give them a call myself.
The idea behind removing the center leaf out of a gasket is to provide more compression but this is a move that only the race teams use to get a little extra out of the bike. If you remove the center leaf you have to plug the oil return passage in the head with a 160 main jet to simulate the size of the hole in the center leaf, if you did'nt do this you would drain the head too quickly of oil as the hole would be too big.
My advice at this point barring me producing any gasket for you (and myself) would be to give Cometic a call. I believe the gasket is very thin (.010") so you would be lowering the head approximately .020" (from stock) causing the desired increase in compression. Of course this will necessitate degreeing the cams.
Cometic would be able to tell you the increase in compression with the gasket swap, I'm going to look into it myself. In my case I would have to make sure my piston to valve clearance would be ok as it is close now (as evidenced by the valve "shadows" in the piston pockets) so I may have to cut my piston pockets slightly. With the stock motor there should'nt be any problem with clearance but again Cometic can give the desired info.
Ahh what we do for horsepower.
