This guy claims 193 on the R1. You decide.
http://www.r6-forum.com/forums/showthread.php?t=32093&page=3&pp=10
:corn
:corn
That used to be true, and can still be true today if the military decides to degrade the commercial signal from the satellites, which would usually be done during some kind of threat or military operation. However, the positional data is used to calculate the speed and if your positional data is off by 20 meters, it will be off by 20 meters at the next point as well. That means the delta is accurate, therefore the speed calculation is accurate.tag r 1 said:i dont want to burst your bubble but the commercial GPS is not all that accurate. The military installs a signal degredation. How do i know , i have installed Sperry and Honeywell GPS sys in aircraft and asked the people who actually make them.They said the military stuff is more accurate by orders of magnitude.
Can't argue with logic.:bowKmac said:That used to be true, and can still be true today if the military decides to degrade the commercial signal from the satellites, which would usually be done during some kind of threat or military operation. However, the positional data is used to calculate the speed and if your positional data is off by 20 meters, it will be off by 20 meters at the next point as well. That means the delta is accurate, therefore the speed calculation is accurate.
Today, the GPS the average Joe Q. Citizen gets is much more accurate than it was 10 years ago.
Moral of the story = Manowar goes 166 mph. Period.
MANOWAR© said:Can't argue with logic.:bow
You just did a few post back and you just now said you don't know how accurate the commercial hand held stuff is.tag r 1 said:I'm not arguing that the stuff today is better than 10 years ago because i don't know how accurate the commercial hand held stuff is . I can't speak for something i don't know.
I don't speak from how someone "explained it to me". After several years of working with GPS based UAV autopilots, and the associated data logging from them, I can tell you from hands on, real world experience that point to point, the error is essentially the same at each point. It does change over time, and over distance, but it's not so quick that it would cause a 166mph reading to be false. IF that were the case he could hold a steady 166 and his GPS would be displaying changing speeds that the bike couldn't possibly achieve. All of this data can be backed up through parallel use of differential GPS.tag r 1 said:That's not the way they explained it . You're assumption that you are off by 20 meters and at the next waypoint you are off by that same 20 meters is wrong.
Its calculated by a GDOP chimney. They use optimum sat's 1 ,2 , 3 , 4.
Then they compare sat's 1 ,2, 3, 5, then 1, 2, 3, 6 and so on until 8 if it's visible then covariance Kalman filter optimization and a whole bunch of other filters i'm sure.
I'm not arguing that the stuff today is better than 10 years ago because i don't know how accurate the commercial hand held stuff is . I can't speak for something i don't know. I do know that Sperry and Honeywell engineers told me that the commercial stuff is not accurate.
I'm really surprised that no one else picked this up too. I've done alot of riding at speed, and the way his engine is howling just screams that it's on a dyno. He certainly wasn't on the road when he took the video of this.mixR1 said:Hooked to a Dyno
You are correct, put two GPS units next to each other and they will both show the same error (within a very small margin, generally around 1cm). The farther away in distance or time the two units are, the larger the error.Kmac said:I don't speak from how someone "explained it to me". After several years of working with GPS based UAV autopilots, and the associated data logging from them, I can tell you from hands on, real world experience that point to point, the error is essentially the same at each point. It does change over time, and over distance, but it's not so quick that it would cause a 166mph reading to be false. IF that were the case he could hold a steady 166 and his GPS would be displaying changing speeds that the bike couldn't possibly achieve. All of this data can be backed up through parallel use of differential GPS.
I don't know of any degredation, but I know that commercial stuff is not as accurate as military units CAN get. I am a Seahawk crewman, and stare at a multifunctional display quite a bit while performing antisubmarine operations. Our GPS, which selects up to 5 satellites, is generally running 16-32 YARDS of EHE (estimated horizontal error). 8 yards of horizontal error is the best our military grade GPS units on the helicopter will go, UNLESS we switch over to using classified transmissions, which we've never bothered doing for the GPS, but have done quite a bit over radio. I can't disclose how accurate they are, but it's not necessarily pin point accuracy.Skanky said:The only reason your GPS can't resolve your position/speed more accurately, is because it just can't - it would take more accurate electronics / clocks inside the GPS unit to do so.
There is no longer any "degradation" of the GPS signal any more - we all use the same satellites (that we know of).
:iamwithstblparker10 said:Looked like 189 o me:dunno
You are not taking WAAS into account. Any WAAS capable GPS in North America will be accurate to 7 meters 95% of the time. In real world use, most WAAS enabled devices will be accurate to 2-3 meters most of the time.TheBFA said:I don't know of any degredation, but I know that commercial stuff is not as accurate as military units CAN get. I am a Seahawk crewman, and stare at a multifunctional display quite a bit while performing antisubmarine operations. Our GPS, which selects up to 5 satellites, is generally running 16-32 YARDS of EHE (estimated horizontal error). 8 yards of horizontal error is the best our military grade GPS units on the helicopter will go, UNLESS we switch over to using classified transmissions, which we've never bothered doing for the GPS, but have done quite a bit over radio. I can't disclose how accurate they are, but it's not necessarily pin point accuracy.
I highly doubt that commercial grade have 20 FEET of error in them. I would say more like 20 yards at best. The statement of 20 feet of error is the same 20 feet of error is not correct. The error is not linear. If the device knew it was 20 feet off in one direction, don't you think it would be able to correct for it and give you the exact point? The error is spherical, and the "20ft" is the radius. It's saying you are somewhere in that sphere of error. So if you moved 20 ft in a straight line, the GPS could read that you didn't move at all, or moved 80ft, based on the max error in opposite directions. The error even changes. While looking at my MFD, I constantly see the EHE changing. I would say it changes every second. I've even seen it get over 100 yards of estimated error.
It varies by unit, my older unit a Garmin GPS III+ samples once per second. But even that unit can accurately measure speed to about .1 mph.Skanky said:Does anyone know how often most commercial GPS systems sample positions to determine speed?
I'm guessing that at near 200MPH, the inaccuracy of GPS is extremely insignificant. Meaning, that if the GPS reads 193 MPH, it probably was 193 MPH.
