I think I need new forks, and I was wondering what year forks will fit? If I got '01, or '02 forks, would I need to get anything else, or are they direct fit?
TIA!
TIA!
:secret:98-01 have 135mm travel.Direct fit, 02/03 has shorter overall length (still useable) and shorter 120mm stroke vs. 125mm stroke on the 98-01 (98-01 are identical). They share the same spring rates.
source please.:secret:98-01 have 135mm travel.
lol, you first!:lol:lolsource please.
oh, and with 02-03 the front guard wont fit, and the axle is different.....Direct fit, 02/03 has shorter overall length (still useable) and shorter 120mm stroke vs. 125mm stroke on the 98-01 (98-01 are identical). They share the same spring rates.
ok, i corrected that post. but it IS 135mm.:thumbupWow you're on the ball, and completely correct about the fender and the axle/nut, however you contradict yourself in another post sateing the stroke at 130mm. Which is it and why should I just trust you? I tend to trust my own experiance and aquired knowledge.
post # 1595
http://www.r1-forum.com/forums/showthread.php?p=3609552
