I'm hoping someone local will buy this but I will ship if I have to. It's a Yoshimura slip-on exhaust for 2007-2008 R1's. It's pretty clean and come with all hardware minus the little spacers that come in the install kit. You could just use washers, I will try to get them before I ship out but I am not promising, otherwise all springs and brackets are there. This will bolt onto the factory Y pipe or Akrapovic Y pipe. Asking $375 + shipping, I'm located in Los Angeles.
In order to be fully honest, the canisters(mufflers) only have 500 -600 miles, they were part of a Yoshimura 3/4 system. I ended up going with a different color scheme so I purchased a used carbon fiber Yoshimura slip-on system and I swapped the inlet pipes off the stainless steel canisters and placed them on the carbon fiber canisters, I then took the slip-on pipes and placed them on the stainless steel canisters. Why go through all this trouble? Because Yoshimura Y pipes only work with their own muffler inlet pipes and I like the Yoshimura sound and this was the easiest way for me to keep the Yoshimura Y pipe and Yoshimura canisters.
