I am using my bike (08-R1)strictly for the track an needed to do a tune up. I wanted to put the OEM NGK plugs back in, but seen some NGK iridium plugs which is a step up. Would that mess up my engine changing plugs? Should I stick with the OEM
I wanted to put the OEM NGK plugs back in, but seen some NGK iridium plugs which is a step up. "Would that mess up my engine changing plugs?"
I just changed the plugs on my 04 R1 yesterday. I ended up going through the radiator from the side. It's a really patient job. You have just enough room to pull coils and swap plugs. It definitely beat taking off gas tank and air box.
Is this technique applicable to the 2009 R1 as well? I need to get to the coils to install my Annitori RL quick shifter..And once you install the smog plates you will find it much easier to do plug changes. Once you drop the radiator down you have plenty of room to get to the plugs from the sides.
I just did this on my 07. You'll get the most space if you pull your plastics and drop the radiator. If you are planning on smog plates too, I'd highly recommend doing that first. It will give you a lot more space with the AIS unit gone. Pay attention to the wires as you work in that area. It's a tight space and it's easy to catch a wire with your wrench mid stroke.Thanks for the reply. Just looking around for a good price now. Now which is the best way to get to them? Radiator pull or taking the top off?
