1 - 4 of 4 Posts
Sal Khan
I went into the FTECU software and was viewing the data stream with the engine off. I just wanted to check to make sure my throttle was fulling opening.
I noticed that it only went up to "96" (I'm guessing that's %). Is this normal? Or should it go to 100?
If is supposed to go to 100 where should I look?
Thanks.
Thanks.
Totally normal
Sent from my SM-G930V using Tapatalk
Thanks.
In fact I think FTECU should change the active tune last column to 95 so that this area gets mapped without applying the same values to 90 %
1 - 4 of 4 Posts
