Status
Not open for further replies.
04-06 R1 - High Beam & Low Beam Use Same Size Bulb?
60K views 11 replies 11 participants last post by  RayJohns
Does anyone know if the highbeam and lowbeam(projectors) use the same size bulb on the 04-06? And if so, is it H7? if not, please tell me the bulb size for the highbeams! thanks!
Save
Yes, I believe high and low beam are both H7 bulbs.
Save
They are the same i moved my piaas i put in the low beams to high beams when i got my Hid's all you need to do is pull off the black adapter on the back of the bulb and plug it inbetween the bulb and wire harness
Save
Would you care to elaborate on that?? I just tried putting them in, and it seems like two metal prongs on the back of the bulb are too close, they need to be further apart in order to be plugged into the adapter. What do I do now? Sorry for the newbish questions, Im new at this.
Save
4 H7 bulbs for 04-08
2 for the lows, 2 for the highs
2 H7 bulbs for 09-10
1 for each projector, projector actuates a plate for hi/lo beams
2 H4 bulbs for 98-03
1 for each housing, H4 bulbs are dual filament
He was scared away by the gayness of the Lucky 13:fact
Save
The little side "parking/marker" lights on the outer edges (when you are looking at the motorcycle directly head-on are T10 bulbs. If you search ebay, you should be able to find them. Try searching T10 LED or T10 LED SMD and you should find plenty.
The high and low beams are both H7 halogen bulbs.
At first glance (if you just un-clip the "bulbs" and pull them out of the headlight fixture), it appears they are two different sizes where they mount into the socket (even though they actually are both H7 bulbs). This is because on the low beams (the two inner projector lights), the H7 bulb seats directly into the metal socket of the headlight housing.
On the high beams, the bulb first plugs into a little plastic adapter thing - which is actually slightly larger than the H7 socket - and then this adapter plugs into the wiring harness and seats into the socket with the retaining clip.
Ray
Status
