04 R1 suspension settings (any update)
1.5K views 34 replies 11 participants last post by  RTSR1
just seeing if there are any info and what might be the best settings for street/aggressive riding.
can't seem to find out on line yet.
Discussion starter · #7 ·
settings before>>
Front
preload 4
rebound 10
comp 16
Rear
proload 6
rebound 19
comp 14
rides very well but want it more firmer
Current>
Front
preload 4
rebound 10
comp 12
Rear
preload 6
rebound 17
comp 12
doesn't feel good at all going to work today and coming home.
feels like it wants to run wide and harder to throw the ride from side to side.
Would like somes pro here to help
Thanks
Discussion starter · #22 ·
thanks Lespaul66 for posting the info. is this setting used for the track or for the street. can't be too aggressive on the street as you can on the track. sad roads in the Bay Area :(
Discussion starter · #24 ·
Re: settings
Lespaul66 said:
These are the R1 -04 settings professional drivers used at Calafat race track when driving master bike test...
Front
preload 4,5
rebound 10
comp 7
Rear
preload standard
rebound 21
comp 4
how can you do 21 on the Rear rebound when the max softest setting is at 20?
Discussion starter · #29 ·
thanks, I will set it up tonight. just to make sure that I am going it correctly which I am sure of.
when you say example 17 out from full. you mean like the book says right. turn it clockwise (a) all the way which is the hardest setting then count it from there counter-clockwise. this is correct??
Discussion starter · #33 ·
hey, rode to work as always and feels pretty good. better then what I had before. going to see more then I get off of work. I will update your later on but wanted to thank you for your help.
it seems harder to find that sweet spot on the R1 as with my 900RR. it was pretty easy to fine tune it.
