what is the wet weight of the 04R1?
thanks,
joe
thanks,
joe
According owner manual, weight with oil and fuel is:HideOut said:its what 375 lbs. dryish? 4 gallons of gas is bout 6.2 pounds per gallon so ... 400ish? Thats my guess.
Hide
:iamwithstEyespy said:According owner manual, weight with oil and fuel is:
425 lbs (U49)
428 lbs (Cal)
Not sure if this also includes coolant. Figure about 3.18 gallons of 50/50 water/antifreeze mix, and also not sure if battery and electrolyte weight is also included or has to be added in.
The '04 also holds more fuel.GXRKLR said:Those weights are odd. SR has the '02 R1 as 438 and the '03 GSXR as 442.
:dunno
The scales will be different just like dyno runs but also the numbers should be consistantly different. The '04 weighs 3 lbs less but hold 1.8 lbs more of fuel. So that's still 1.2 lbs lighter this year but some how weighs more than a bike that it was 4 lbs lighter than the year before. That's the point I'm getting at.r1-superstar said:The '04 also holds more fuel.
NO, I meant qts, not gallons.Scooby said:Eyespy quote:
Hey Eyespy, you meant pounds here didn't you? :yesnod
I hope to god a bike never needs three gallons on antifreeze, that would be a big bike :lol
