Hi all, new guy here hoping someone can confirm weather the 15 R1 stability control self calibrates for different size tires or not? I normally run a 200 slick at the track.
Interesting. On the Pirelli international site I see that tire in the list. On the US site, plus the (US) spec sheet I have, that option is not shown.I'm using 190/55 Pirelli Superbike Slick SC2....allmost the same radius as recommended in the manual.
When you get that code try to change your settingsI'm running a 200/50 dunlop q3 on an R1M (original 200/55) So far no issues has come up, no codes and electronic aids are working fine.
*** incase anyone runs their bikes on a rear stand in gear, you will get code 69 pop up. It clears after you first take it out. Code 69 is the front wheel speed sensor no signal so no need to worry about it!
You know it's locked....When you get that code try to change your settings
I don't know how do you reset it without riding the bike other than using YDT but will be happy to learn :wink2:You know it's locked....
(and it can be reset without riding the bike)
Do you disconnect the fuel pump for it?I just follow'd the instructions in the service manual to clear it.
Not the most logic way...but it worked (I cannot just take a ride, since it's track-only)
No....it's all done via the dash.Do you disconnect the fuel pump for it?
The procedure fort getting into the diagnostic mode on the dash is:No....it's all done via the dash.
We all got that. What you didn't get is that going "for 20 sec of real road speed" doesn't help you when you on the track, your session is about to start and you need to load your new settings.GUYS ***** the code clears itself after 20sec of real road speed no need to worry! I just mention that if you run the bike in gear on the stand it will set code 69 but it will clear itself immediately after you take it out for a spin on the street.
it doesn'tNot wanting to hi-jack the thread, but I've seached to no avail; if you change sprocket sizes on the R1, how does it affect the TC etc?
It doesn't, because the sensors are on both wheels, opposite to the older '12 model where the rear wheel speed is read from the camshaft sensor (derivated).Not wanting to hi-jack the thread, but I've seached to no avail; if you change sprocket sizes on the R1, how does it affect the TC etc?
