190 vs. 180 tire
1.6K views 14 replies 13 participants last post by  knedgr
What are the pros and cons of going with a 180 or 190?
180 may offer quicker turn in due to steeper profile... and less mass to accelerate
I made the swich to a 180 years ago and liked it right away, for reasons already said. I think they are easier to find as well cause there is alot of 600 and 750s around here I can get take offs from and the dealer stocks a wider variety of 180s too
On an R1 how does switching to a 180 effect the height in the rear. Do you need to make any changes to your suspension? I have one on mine and like it but when I bought the bike the original tires (190) had flat spots. It obviously felt like an improvement!
#8 · (Edited)
BS BS BS BS......... That turn in crap is all BS..... The reason the 190 is harder to turn in is incorrect suspention and ride height adjustment. If you correct for either size, U would be hard pressed to know the difference......(In regard to turn in speed)
180 saves U dough and gets less mass there for spins up quicker.... To get power down in a straight line go 180. U want stick in corners go 190.....
190/55 is best option for 190 but not all vendors make it...
Good luck in your decision.
Sorry I dont mean to bash the quicker turn in comments but that is only if U slap a tire on and make no geometry changes ...... Leave your 190 on there and drop the front ride height 1-3 mm's and voila the quicker turn in argument for a 180 is gone (amount of drop is dependant on tire manufacturer)
#11 ·
I run PP 190/50 now but i will definitely get PP 2CT's in the 190/55 next change out. they dont make PP 190/55 just regular. The 190/55 has the most contact patch in the turns and that means everything to me. I think the spinup/rotational mass argument is true but it is a cost benefit situation for me. Safety in turns or faster turning/ accel speed, it is all about what is more important to you. I would never go down to a 180/55 though....
If it's a Michelin the 180 has a larger circumference than their 190 which raises the back end of the bike ( I do not recall the exact amount ) that is why you would notice the easier turn in. I've been told R1's react nicely to raising the rear of the bike as much as 15mm. Although I don't think the tire alone does that it may be as much as 10mm.
A much cheaper way to find out than an adjustable length shock !!
