ok so i searched this forum for a specific write up for an 01 R1 radiator switch mod and could not find anything sooooo I went at it alone lol. I have some questions and I hope you guys can correct my process if I did anything wrong.
Once I get my facts correct I will post a detailed write up along with some pics for all your 2001R1 owners but first I have questions.
I basically spliced into both the wires that come from the thermostat and ran them to a lighted switch.
Now if I ground the switch my fan will come on but the LED on the switch will not light up. If I do NOT ground the switch the LED on the switch will light up but my fan will not turn on, WHY?
What am I doing wrong or is a lighted switch just simply not compatible with this setup?
Also, when I manually turn the fan on with my switch mod, the HI temp light will light up, is this normal since the ECU thinks it’s actually overheating? Once I turn my fan off with my switch, the HI temp light goes away. My question is, Will this affect anything or is this just the way it’s going to be when I run my fan manually?
If anyone can help me answer these questions id be more than grateful, after I confirm my setup is setup properly I will take and post a detailed write up for everyone.
Thanks in advance for any answers.
-Robert
-Robert
