Dec.19th---STILL NO CONFIRMED FIX for this problem
Sept.2005-STILL BROKEN-no confirmed fixed
2 years and heading to the third of this problem.
UPDATE DEC.4,2004
I THINK WE MAY HAVE THE FIX---VERY LOW TECH FIX...
i SPOKE TO PASCAL PICOTTE AND HIS HEAD MECHANIC TODAY AND HE SAID WE NEED TO ADD MORE COOLANT. THE COOLANT LEVEL CAN DROP BY 200-300CC AND IT WILL EFFECT THE THERMAL WAX PLUNGER CAUSING THE ECU TO THINK SOMETHIGN IS WRONG AND SHUT OFF THE BIKE---NO ERROR CODES CUZ NOT ELECTRICAL. SO ADD MORE COOLANT AND IT SHOULD FIX YOUR ISSUE. HE SAID HE HAS SEEN IT BEFORE....WE CAN TEST IT BY LIFTING UP THE GAS TANK AND YOU WILL SEE IF THE PLUNGERS ARE MOVING PROPERLY AS THE COOLANT CIRCULATES AND HEATS UP THE WAX....CAN SOMEONE TRY IT AND LET US KNOW.
UPDATE---OCT1-2004
Now I think I know what the fix is, at least for my problem which seems to be the same as alot of you.
I have been testing my bike for close to 1000km.
It has a new ECU and matching throttle body. THe problem lies with something on the throttle body since it has alot of sensors and connections and not the ECU since this is now the 3rd ECU. Any mechanics here that can explain whats on the throttle body?
The weather has cooled down here but it was fairly warm today (22c-but cool).
I ran it in traffic for1.5 hours today plus another hour at night.
It is running very well now. The fan was running at 105c hit 108c and still ran fine in traffic moving less than 30kmh.
BUT, what if we get the same crappy part that will act up in another 6000km....hmm
TO YAMAHA- contact me-I have DETAILS for this problem.
Weather, conditions, humidity, times, fuel, I even have oil that I saved.
I think alot of you might run into this soon:
1. 2004 R1 with 12500km
2. ran fine until 6000km
3. ECU replaced
4. Exup adjusted
5. richened up-no longer lean
6. happening for over 6 weeks now
7. bike in shop for 6 days now---will go back for a day 7 this week.
PROBLEM
When I come to a stop the bike would just shut off. Sounds like a wind down sound. Like an electrical motor winding down to off. The dash lights stay on. I have to turn it off with the key and restart it. This used to happen in the hot days but now it happens at night and within 100 yards after i come out of my driveway in the mornings now. It HAS gotten worse for me.
This is happening more often (daily now) it happens when it is hot. It happens when it is cool.
It happens riding for less than 10 min or after 1 hour.
I am in Canada. If you had this happen to you and it was fixed (wherever you are from), please pm me with name of shop and location so I can get Yamaha Canada to call them. Also let me know exactly what they did to fix your problem.
Dam---they have me doing all their trial and tests for them.
Did I tell you I almost got rear ended a few times at stop lights.
PLEASE PROVIDE THE FIX IF THIS HAPPENED TO YOU.
ONLY POST IF THIS IS HAPPENING TO YOU AND PLEASE UPDATE YOUR 1 POST AS YOU HAVE PROBLEMS AND FIXES. THE GOAL IS TO KEEP A RUNNING JOURNAL OF OUR PROBLEMS AND TRACK IT EASIER FOR ANY FUTURE ISSUES.
Thanks everyone,TO YAMAHA- contact me-I have DETAILS for this problem. TO YAMAHA- contact me-I have DETAILS for this problem.
UPDATE DEC.4,2004
UPDATE---OCT1-2004
3. ECU replaced
4. Exup adjusted
PROBLEM
