1 - 2 of 2 Posts
chapu
· i want to be fast...
Discussion starter · #1 ·
First some history i put in a HID kit everything was working fine for like 4 days then i went to turn the bike on and my lights did not turn on, the tail light is working fine and so are the back turn lights but the front are not and on the speedometer the high beam light is turned on even tho i dont have the beams turned on, i checked the fuse and its not burnt what else can i check is there a relay that maybe died? please someone help i need my bike for work and i need my lights to be able to ride it thanks.
Alex
I have the same issue....i believe i am going to have to run hard wire to the battery and put a relay in it....i think whats going on is the factory harness does not send enough power to fire the ballasts.....what you will probbly find is if you turn your bike one (and the lights dont work ), if you unplug one side the other side will fire...then if you plug in the second it will fire.
I think there just isnt enough voltage to fire both ballasts :(
1 - 2 of 2 Posts
