2004 Suspension Help
593 views 9 replies 3 participants last post by  R1_enough_said
I'm seeking good suspension setup for the 04 (aggressive riding) for myself, full gear weighing 210-215 lbs.
I'm running the stock 218's.
Needing setup, and recommended tire pressure.
Thanks,
Mike
ACCORDING to June 2004 Sport Rider
FRT:
preload: 3 lines
Rebound: 7 out from full stiff
Compression: 9 out from full stiff
5mm showing above triple clamp
REAR:
Spring: 8
Rebound: 21 out from full stiff
Compression: 7 out from full stiff
suggest you use these mayhap as a starting point; adjust one at a time; use at own risk
WRITE DOWN STOCK SETTING BEFORE ADJUSTING.
FRT:
preload: 3 lines
REAR:
Spring: 8
Did this setting show the riders weight in the magazine ??
Naw but somewhere I remember the testers are @ 185-210 in weight I weigh in at 236 and am pretty much stock on the settings. Wound up not to far from the settings in the mag.
'04 Suspension Set Up
Try this...
Front
Add 3 clicks rebound (7 out)
Compression and preload stock
Rear
Set the preload/spring to maximum (#9)
Add 7 clicks compression (5 out)
Rebound stock
You weigh more than me but this should be a good start for fast riding including track days.
MCR1 curious if you feel the spring on the rear could be replaced as it seems it has to be wound up all the way have contemplated getting a different one. ???????
Rear Spring Rate
Our Ohlins importer is expecting his first shipment of shocks for '04's within a matter of days and i'm at the top of his list. As I understand it the standard spring is 8.5kg and should be 9.5kg for hard riding/track use. According to AMCN magazine this was a comment made from a Yamaha technical adviser at the launch in Australia. The bottom line is they are still road bikes and need to be firmed up for track use.
