Not sure if this is a repost...but finally I saw the official 2006 R6 engine power figures...
Engine type 4-stroke, forward inclined, parallel 4-cylinder, 16-valves, D0HC
Engine cooling Liquid cooled
Displacement 599cc
Bore x stroke 67.0mm x 42.5mm
Compression ratio 12.8:1
Maximum power With direct air induction: 97.8kW (133 HP) @ 14,500rpm / Without direct air induction: 93.4kW (127 HP) @ 14,500rpm
Maximum torque With direct air induction: 68.0Nm (6.93 kg-m) @ 12,000rpm / Without direct air induction: 66.0Nm (6.73 kg-m) @ 12,000rpm
Lubrication system Wet sump
Carburettor/Fuel supply Fuel injection
Clutch type Wet multiple-disc coil spring
Ignition system TCI
Starter system Electric
Transmission system Constant mesh, 6-speed
Final transmission Chain
Fuel tank capacity 17.5 litres
Oil tank capacity 3.4 litres
Displacement 599cc
Ignition system TCI
