R1 Riders,
When the engine is off and no key is in the ignition, when you go to turn on the bike by just rotating the key to on, the ECU tests the YCC-I variable length intake funnels, by making the funnels go up and down, and you can hear this, the sound normally sounds like a good crisp strong weep-weeeeeep.
Today, on my 07 R1, I noticed, that when I turned the key to on, the first weep sounded ok, but the second sounded like wepeepeepeeep. What sounded like a very stuttered and labored effort by the servo to get the funnels to come back down.
Then, when the engine is actually running, and you still have the key in the on position, and go to turn off the engine by using the red kill switch, after the engine stops running, you should normally hear the weeeeeep of the funnels placing themselves in position, but the same issue occured for me again, when I actually heard the same labored stuttered sound of the funnels moving, the same as I had heard before the key was rotated to on when the ECU tests the funnels.
Has anyone else encountered this problem, heard these stuttering noises, know of this issue, know what the solution is?
Thanks,
Zer0Sum
Thanks,
Zer0Sum
