Crap.. Got tar on my rear tire.. worry or not?
907 views 6 replies 7 participants last post by  george536
It was quite hot. Decided to take the R1 for a spin. Yes, i was fully geared...
Must have ran over a soft patch of tar and a good tar (maybe 3" in diameter) is stuck to the middle of my rear tire. Scraped most off but still some on.
Should i worry since it's not on the side of the tire?
You can use a little kerosene to clean it off if you're really worried about it. Follow up with some warm water and dish soap after that. Since it's in the middle of the tire you don't have to get your panties in a twist. It's not like you'll be losing corner grip.
I'd carefully remove any solid pieces out of the tread and call it a day. Friction will remove the rest on your next ride.
