1 - 20 of 31 Posts
here's a little more to compare with the R1.
http://www.metricbikes.com/2004bikes/YZRC.htm
YZR-M1 - Specifications
Engine
Engine type: Liquid-cooled, in-line, 4-cylinder, 4-stroke with 20-valve DOHC
Displacement: 990cc
Ignition: Yamaha CDI with adjustable mapping - NGK spark plugs
Carburation: Fuel injection
Lubrication system: Wet sump - Motul Oils
Data recording: 2D
Maximum power: More than 240 hp
Maximum speed: Over 320 kmh (200 mph)
Transmission
Type: 6-speed cassette-type gearbox, with alternative gear ratios available
Primary drive: Gear
Clutch: Dry multi-plate slipper clutch
Final drive: Chain - DID
Chassis and running gear
Frame type: Twin-spar aluminium frame, multi-adjustable steering geometry, wheelbase, ride height, with aluminium swingarm
Front suspension: Fully-adjustable Ă–hlins inverted telescopic forks
Rear suspension: Braced aluminium swingarm with single Ă–hlins shock and rising-rate linkage
Front/rear wheels: Marchesini 17.0 inch front, 16.5 inch rear, available in a variety of rim widths
Front/rear tyres: Michelin, 17.0 inch front, 16.5 inch rear, available as slick, intermediate, wet and hand-cut tires
Front brake: Twin 320mm carbon discs with radial mounted four-piston Brembo calipers
Rear Brake: Single 220mm ventilated stainless steel disc with twin-piston Brembo caliper
Weight: 145kg, in accordance with FIM regulations
Fuel capacity: liters, in accordance with FIM regulations
response
The biggest difference is that rossis M1 now uses a four valve per cylinder setup instead of the r1 five valve per cylinder setup. :hellobye
Re: response
BAHHAHAH... that's the biggest difference huh? I'd say the PRICE TAG is the biggest difference! :sneaky
Re: Re: response
Ding ding ding...Tell him what he's won Johnny!
witz said:
What is the difference between the M1 that Rossi rides and the R1 sold to the public? Will we see the M1 for sale soon?
It will be a cold day in Hades before you see an M1 sold to the general public. What you will see is technology developed for the M1 incorporated into the sportbikes Yamaha produces.
The GP bikes are always testing/proving grounds for new technology in pursuit of the most awesome machines.
As far as I know, only 1 person outside of the Yamaha Corporation owns a Yamaha M1, that would be Rossi himself, a well deserved gift for what he's done for Yamaha's GP program.
Don't forget the M1 has reinforced, cross drilled, anodized carbon rotator spools...That's why it's so much faster. Too bad slip ons are so expensive for it, otherewise I'd have one for my daily commute to Hawaii
1 - 20 of 31 Posts
