PsyKotiC RydeR said:
so how do you brake without locking them up when you have to slow down to hard and fast to avoid an accident or any other cases? thanks..
im not a guru, but ill tell you what lil i know, from what ive seen and heard, its a big debate.
but for regular braking, it should be 70% front, 30% rear, just enough to both dont lock. but in the case the back does lock, the correct thing to do is keep it locked and finish the slide. if you let it go, and brake again, it causes you to highside. so do 70/30, if it locks, hold it down all the way until bike stops and dont let go.
racers like keith code teach to never use back brakes period, all front.
finally, it is proven that if you use both brakes instead of just one or the other, you stop the fastest and ccrider courses will teach this is the most efficient way to stop.
with this teaching from ccrider and keith code, id say its up to you to know these facts and recommendations, and figure out whats best thru experience.
personally, i always do 70/30. i havent rode track yet, so i dont know if braking at high speeds is best only done from front brakes like keith teaches. but from my experience , 70/30 works well. and if back locks, which has happened to me several times, i keep it locked even harder and come to a complete stop just fine.
its when you let go, and hit the back brakes again very quickly that makes the bike throw you off
im sure other gurus on this site can give better input on this. :beer
