alas yes Noximus & pR1mal, gear advanced mapping is the way to go... i never had a chance
to see what AFR's looked like while riding previously so i really did not know what was what with a basic map...
i could only go by ear and she did start to sound good after the 3rd map i made, but i always found 2nd & 3rd a little weak.
not totally gutless but they definitely checked out a lot sooner in the rpm range than i would want to..
no such thing anymore, so many thoughts swirling around in my head, doing gear advanced mapping is both easier
and infinitely more difficult as there are a few variables that play with each gear and you really need to know your
bike to be able to detect where things are going.
so far i found the beast way to tune this monster is by looking at the POD for what % throttle you're in,
if you're sitting at 5% TPS then you can throttle it up to about 15% and as the RPMs climb to a certain climax you're happy
with instead of letting go of throttle just bring it back down to 10% n' let the revs drop all the way till you can feel she's leveled
off to match TPS.. that way every RPM the engine hits on the way down will be read for the 10% column...
if you do this for all gears as much as you can, specially in the mid range things really begin to shape up..
2nd and 3rd gear are finally useable again, it trully is a world of difference from what i'm used to, you can definitely feel RAM air
and how it affects the drive-ability of the gear youre in... revs are allowed to climb and since you start making power earlier
then it all comes along for the ride, next thing you know there's zero need to shift as you're passing cars... very easy
to do so now both in 2nd & 3rd, just roll on and roll off.. 4th feels great in cruising mode but a little weak still off 5k rpm..
I will have to mess with 4th gear mapping to get the best out of it... 5th is a total dream out in the freeway
along with 6th, both cruising at 13.4 are just perfect.. plenty of get up and go yet not breaking the bank at all..
i'm very happy with the results thus far,... if anybody is on the fence regarding the AT & POD as tuning tools i highly recommend them both!!! :fork
Since the fueling requirements are different for each gear, if you don't run gear advanced the AT will constantly trying to modify a single map for the different running conditions of each gear. It will always be chasing it's tail.
:yesnod
there are parts of 3rd gear's rpm bandwidth that felt to be in the ballpark after tweaking the basic map but honestly it was just too much work..
and it was very evident if i had been riding tight and twisty bits as soon as i tried to get some real power out or 3rd there just was nothing there.
it really had a hard time making power on the lower revs, of course its fueling requirements are worlds away from what 4th can get a way with
and the custom map i was running though tuned for 4th was done on a dyno, which cant possibly account for RAM air... both these maps have
taken the most work really, its a fine line between power and smooth power, a very fine dance at least for my riding style.. :fact
i wore my ear plugs all day so i would not get distracted by the engine sound as i tuned, opted more for how each gear felt and man oh man was
I ever in for a treat... i rode with a huge smile on my face all day after having accepted yesterdays TRIMS at a local ride, at the end of the day
as i crossed border back into Canada (rode WA state backroads today, so much fun) i left the plugs off, woah, the engine roars to life right into
idle n' sits there happy at 13.4afr (currently) and it rumbles and clears its throat into life as you gas it off 1st... revving into position along with
the rest of traffic both in 2nd & 3rd is a truly wonderful experience, you can literally feel how much happier the engine is with a set 13.2AFR from
the word go up till 5kish when cruising range starts, you can easily sit in 3rd gear through both fast and slow n' tight roads, plenty of go from
both of those lower gears... no longer does it feel like they fall flat on their face if you throttle down or off altogether, REVs feel extremely uniform & smooth :boobies
