Hello, I'm new to the forum, and I have a question please.
I have searched through here and spent a few hours looking for any problems similar to mine but haven't really found anything solid.
My bike (01 R1) was running perfectly, except for clutch slip, and then I lowsided in a curve and my bike hit the wall.
Damage:
broke right clip on
Bent exhaust mount/peg
slightly rashed right side cover
rear rim = trashed
clutch slider and rim took most of the damage.
NOW:
I have the bike all put back together and here are the problems:
The fan now will run constantly, were as before, it wouldn't run until around 205 deg. F. and secondly, the bike runs fine, until around 6-7.5k. Here it will cut out, backfire, and bounce off of those rpm lines like they were the rev limiter. Tac needle goes crazy.
Carbs look very clean, air filter looks brand new. I checked the whole left side of the harness, no shorts. I checked my battery, it is fine. I checked the primary resistance and secondary resistance on my coils. The secondary is fine, but the primary is half an ohm too high on each coil pack. I checked my throttle pos sensor. I assume I take three readings for the three prongs? One reads perfectly, one reads infinite, and the other reads bad. The red wire on my R/R was previously fried, and a new wire was patched in and hooked up. The white plug that goes to my stator was not burned. My battery will hold a charge, but i'm having this terrible problem at 7k with cutting out, backfiring, and the tac needle going crazy. Is it possible that just the regulator part of the R/R went out and not the rectifier part? Is it my TPS sensor? I'm freakin depressed! can't ride my bike like it's made to be ridden! :cryin
Damage:
broke right clip on
rear rim = trashed
NOW:
