Front stand for R1M
13K views 38 replies 22 participants last post by  easbaysav
The R1M has a sensor that can be crushed if you use a conventional front stand. To negate this, I bought a pit bull triple tree front, but what a pita it will be wrestling with tire warmers and a triple tree front stand!
So then I was browsing some M photos online and stumbled upon this. What stand is this, and how are they not crushing the sensor? Anyone have any idea?
You're over-thinking this. The triple-tree stand is fine and not a pain at all. In fact, most guys I see in the paddock use a triple-tree stand than anything else.
#29 ·
Ok,
Found a few different cone front stands on fleabay.
Professional Race Track Front Fork Lift Sport Motorcycle Paddock Stand BW 06 | eBay
The only issue I have is that the cones are bare metal without any delrin or nylon cover to prevent scratching up the front suspension hole and bottom.
This stand works great btw. Despite also having a pitbull front triple stand w the correct pin, i too prefer the ease for track days of a standard stand, and Ronnie, scratching doesnt seem to be an issue because of the shallow angle of the pin.
#22 ·
Yes a fork lift stand would be an issue with both R1 and R1M as they both have that same sensor. This is easily rectified by using a triple tree lift and the appropriate pin which I believe is 6s but I'm not 100% on the pin. Pit bull is by far my favorite.
Am I missing something here. Put-bull tire stand and tire warmers :dunno:
The pit bull stand is by far the best I had I even got my dealer selling them now it's quick and easy can't knock it till you try it
#35 ·
Redgecko,
If you are referring to Pit Bull pins, the R1 ('98-'01) is a #8 pin, the R1 ('02-'14) is a #8T pin, and the R1 ('15) a #8S pin. I have both the #8 and #8S and both will work on the '15 but the #8S does give you more room/clearance to insert the pin.
-John
#39 ·
Just for general info, George Hoffman (the owner of Pitbull) sent me this new pin specifically for the 2015 R1. Very slight angle makes for a super sturdy fit. #36 (for those who cant read upside down :grin2:
They need to update the fitment chart, I ordered an #8S awhile ago because that's what was recommended. I do notice that the pin isn't snug in the hole, but it does work so I'm gonna stick with it for now.
