HOW TO: 09-13 R1 Custom LED Tail Light Install
22K views 34 replies 19 participants last post by  ussprinceton
Okay... So I did a search for this before I installed my New Integrated Tail Light, and couldnt find a how to for it...
This is my Write up with pics fo help anyone out that is doing this install.
Excuse the crudeness of my descriptions, I am not a mechanic, just a regular guy doing a write up for other regular guys that need help with putting in a tail light.
Tools you WILL NEED...
5mm Allen Wrench
4mm Allen Wrench
Small Phillips Head Screwdriver
Tools you may need
Small Flat head Screwdriver
Needle Nose Pliers
Here is my bike... Before anything is done
Insert Key into back seat lock, remove back seat
Remove Front (drivers) Seat with 5 mm allen wrench
Remove the Push Pins from under the undertail (you may have to use the small flat head screwdriver to pop it out
Take the bolt out from the TOP of the tail peice with 4 mm allen wrench
Pic with out the bolt
Take out these two push pins with a phillips head screwdriver
Another look at where they're at
What it looks like without the pushpins
If you have stock cans... Remove these plastic covers with a 5 mm allen wrench
Remove push pin from above the exhuast, and below the undertail on each side *right by my thumb*
(you might need a small screw driver or even a very thin allen wrench to poke the center of it out)
Push the top tail peice UP and toward the BACK of the bike * the direction I am pionting* Take note: the the bottom corners of the tail peice over laps the under tail and you have to pry on it A LITTLE to come over the undertail, try not to FORCE it, but you will have to flex it a little bit to make it come off.
Will look like THIS once it pops off
Pull your tail fairing off. I placed a sheet on the tank and frong seat area to keep from scratching my fairing.
Note: Your Rear Seat locking mechanism will STILL BE ATTACHED when you pull the fairing off *will look like this *
Remove the two bolts from the locking mechanism. ***SEE NOTE IN NEXT STEP BEFORE PULLING LOCKING MECHANISM OUT!!!***
Note : Under the locking mechanism there is a small White plastic spacer. If you're not careful, it will fall out when you pull the mech. out. This plastic peice WILL fall into your bike and be hard to find if you're not careful This is what it looks like...
Remove plastic push pins with a philips head screw driver *one on each side*
Remove the two black plastic covers *in the center of the pic* by removing the four silver bolts with a 5 mm allen wrench
Remove the two black bolts and the aluminum peice
#2 · (Edited)
Remove Push Pin with philips head screwdriver from the rear storage compartment
Looks like this removed
Remove Push pin from plastic tray (just behind battery)
Disconnect all wires and wire harnesses *this is what it should look like before you pull anything out
Pull your tail light, turn signal and plate light wires out of the way and remove this black box by simply pulling up on it ( it's held in place by a rubber grommett)
Remove wire harness from this white box
Pull back all wires and remove this fuse box. * held in by a clip *
Remove this small red and white fuse box
Take out the little silver peice here, by removing the bolt that holds it down *this holds the plastic tray in*
Pull all wires back and remove plastic tray
Remove three bolts in the tail with 5 mm allen wrench * holding on the license plate bracket if you still have it on the bike *
Looks like this with no bolts
Remove silver screws * in center of pic, one on each side * from under the subframe with a phillips head screw driver. You WILL have to push the undertail piece of plastic to the side a little bit to get at the screw. It's also very easy to drop this screw so be careful not to drop it.
Remove two silver screws from stock tail light peice (sorry bad pic)
Pull out the black bracket. *I had to pry down a little on the undertail fairing to pull this bracket out*
Remove the rubber cover from the stock tail light (sorry bad pic)
Pull out stock tail light housing * I had to twist and turn and manipulate mine just to get it out *
Pictures are going to be the same as the ones coming out, so they will look the same, but reverse....
Next you put the new tail light back into the tail fairing.
Put the rubber grommet back on top of the new tail light
Insert bracket back into the tail fariing and put the two screws back in the top.
Pic with no to screws
Top screws in place (one on each side)
Put the two sivler screws back in through the bracket, into the back of the new housing.
Reconnect your plate bracket with the three bolts (if you have it )
Place plastic tray back in
Put the silver peice of metal back into place by putting the bolt back in place
Reconnect all the wiring harnesses in the plastic tray
Put the push pin back into the bottom of the tray (right near this fuse harness)
Put the push pin back into the tray ( near the bolts that hold the license plate bracket on )
Place the aluminum bracket back on with the two black bolts
Put the two black plastic pieces back on by putting the four silver bolts back in .. * here * (one on each side)
Put the two black push pins back into the piece of aluminum ( to connect the fairing back on to the aluminum peice ) * Here*
And Here
Set your upper tail fairing on the seat of the bike
VERY CAREFULLY place the plastic spacer back into its place in the subframe, and set place the locking mechinism on top of it. NOTE: Be SUPER CAREFUL NOT TO KNOCK THAT PLASTIC SPACER OUT OF ITS PLACE. It's really easy to do ( i did it TWICE) and can be a real pain in the neck to find if it pops out of there)
Put the two bolts back into their holes to hold Locking mechanishm in place.
#4 · (Edited)
I had a hard time with the spring being all outta place when I put the locking mechanism back in. I had to use a pair of needle nose pliers to pry the spring back into its proper place. Here are a few detailed pictures to show you how the spring and mechanism should be properly placed.
Close up from the left side of the bike
Close up from the right side of the bike
Close up from IN the storage compartment toward the left side
Put your upper tail fairing back on the rear of the bike, and slide it down and back into place. * the opposite direction that I am pointing *
Put the black push pins back in the tail piece, * on the underside of the fairing, and above the exhaust * (here) Pic without push pin
With Push Pin
Put the push pins back into the top part of the tail fairing Here and here, without push pins
Here and here WITH push pins
Put the bolt back in to the top of the tail fairing
Put the push pins back in on the underside of the fairing
with out push pins
With push pins
Put the covers back over the exhaust ( if you have stock cans )
Put the drivers seat back on with the two bolts
Put the passesnger seat back on
Task Complete
This may not be the best write up ever, but the intention is to assist other people when they are installing an integreated tail light.
If there is anything that you guys think is wrong, ( or I have photos that are placed incorrectly ) please let me know about it, and I will do my best to update or change the problems.
Hope this helps someone else out.
This is what I was looking for! Thank you so so much for this STEP by STEP presentation with each pic of what you were talking about and what screw or plastic pin you were removing. This is so much better than the other 'How To' install tail light. I was stuck in the middle of changing my light out following those steps. You picked me up where I was stuck at and brought me to light. Thanks once again for the EXCELLENT presentation!
Great write up...I hope to receive my tail light early next week and will be using this guide to help me install it quickly and properly. :)
Hmmm. I guess I didn't include that part did I? Well, I'm thinking mine was plug and play, I'll have to double check that and update my posts.
Thanks for the advice bro. I'll update soon.
One thing when looking at this, it might be easier to not take the plastic tray out of the undertail. Its not that difficult to just remove the lower draft shield and the headlight comes out with it, just leave the plastic tray in and remove the lower with the tailight and change it there. My .02 cents after removing all fairings the other day.
#22 ·
Awesome! Thanks man.
I wrapped it up yesterday and it works perfectly. The only thing I'm not crazy about is the fact that I had to look at all the missing hardware from my bike.
Anyone know where I can get a bag of the little push pin clips? I'd like them to be exactly what's already there.
