2 months ago the r1 died after starting and running for 20 seconds. I found out that my gas tank cap was leaking water into the tank so there was a bit of rust that got sucked into the fuel system. I've replaced the fuel pump and strainer due to caked rust. I've cleaned the tank out and flushed the fuel lines to clear deposits. Spark plugs were a little fowled and I replaced them with oem plugs. I bench tested the primary and secondary injectors, the secondary injectors mist out the way they are suppose to but the primary injectors spray in awkward "V" patterns inconsistently.
I replaced the injectors with a used set without bench testing them and have the same starting issue.
Starting: So the bike will start with starter fluid. I only fired it once this way just to confirm spark, air and battery power.
The bike cranks but does not catch. Just burps every other turn cycle. The bike cannot be push started, it does not catch in 1st, 2nd or 3rd gear at ~ 9-12mph.
Just need some opinions on where to go from here. I'm going to try another known good set of injectors next week. Do we have fuel filters on our bikes?
...and how strong should the fuel pump be pumping during priming cycle?
