Introducing the 2006 YZF R1
68K views 221 replies 93 participants last post by  YzRacer212
YZF-R1 LE OPEN CLASS RACE BIKE
The exclusive limited-edition!
2006 R1 LE—Complete with back torque-limiting slipper clutch, Marchesini wheels, adjustable rear suspension link and Öhlins suspension developed specifically for this model—all that on top of the standard R1’s "06 upgrades. The R1 LE features Yamaha 50th Anniversary Yellow/Black paint with special trim and badging.
• 43mm Öhlins custom-valved fully adjustable inverted fork w/ two-way compression damping adjustment
• Öhlins custom-valved fully adjustable rear shock w/hydraulic preload adjuster and two-way compression damping adjustment
• Gold Marchesini forged aluminum wheels
• Adjustable rear suspension bottom link
• Pirelli Diablo Corsa tires
• Starter button doubles as lap timer control
• 50th Anniversary Yellow/Black w/ gold chain, exhaust covers and tank emblems
YZF-R1 OPEN CLASS ULTRA HIGH PERFORMANCE
Both standard model R1's features:
Building on the most sought-after sportbike in the industry, the 2006 R1’s modified frame, longer swingarm and revised front forks sharpen handling, traction and responsiveness—while a revised cylinder head unleashes an additional three horsepower. No other motorcycle combines performance, style and ridability like the R1.
Now we'll kick it off with standard version pics... and some statistics info.....
• 998cc fuel-injected liquid-cooled 20-valve DOHC inline four-cylinder
• 43mm fully-adjustable inverted fork
• Fully-adjustable linkage-mounted rear shock
• Dual 320mm front disc brakes w/radial-mount forged four-piston calipers
• Team Yamaha Blue/White; Raven; 50th Anniversary Yellow/Black.
ENGINE
* TYPE : Liquid-Cooled, 4 stroke, forward inclined, parrallel 4-cylinder, 20 valves, DOHC
* Diplacement : 998cc
* Bore and Stroke : 77.0 x 53.6 mm
* Compression Ratio : 12.4.1
* Max Power :
* Max Torque :
* Lubrication : Wet Sump
* Fuel Supply : Fuel Injection
* Clutch Type: Wet Multiple-Disc
* Ignition : TCI (Digital)
* Starter : Electric
* Transmission : Constant Mesh, 6 speed
* Final transmission : Chain
* Primary Reduction Ratio : 1.512
* Secondary Reduction Ration : 2.647
* Gear Ratio 1st : 2.533
* Gear Ratio 2nd : 2.063
* Gear Ratio 3rd : 1.762
* Gear Ratio 4th : 1.522
* Gear Ratio 5th : 1.364
* Gear Ratio 6th : 1.268
CHASSIS
* Frame : Aluminum Dia Cast Deltabox V
* Front Suspension : Telescopic Forks, @ 43mm
* Front Wheel Travel : 120 mm
* Rear Suspension : Swingarm (Link Suspension)
* Rear Wheel Travel : 130 mm
* Caster Angle : 24 Degress
* Trial : 97 mm
* Front Brakes : Dual Discs, @ 320mm
* Rear Brakes : Single Disc, @ 220 mm
* Front Tire : 120/70 ZR17 M/C (58W)
* Rear Tire : 190/50 ZR17 M/C (73W)
#11 ·
DIMENSIONS
* Overall Length : 2,085 mm
* Overall Width : 720 mm
* Overall Height : 1,105 mm
* Seat Height : 835 mm
* Wheelbase : 1415 mm
* Min. Ground Clearance : 135 mm
* Dry Weight : 173 kg
* Fuel Tank Capacity (reserve) : 18 litres
* Oil Capacity : 3.8 litres
#18 ·
FZ1 REAL-WORLD HIGH PERFORMANCE
For 2006, the world’s best streetfighter is all new, blending exceptional style and character with open-class performance like only Yamaha can. A current-generation fuel-injected R1 engine tuned for the real world sits low and forward in an all-new, aluminum frame with a longer, Controlled Fill swingarm. The new FZ1 is a more focused, more aggressive, more intensely high-performance motorcycle in a smaller, tighter, meaner package.
• All-new aluminum frame
• Aggressive yet comfortable upright riding position
• Controlled Fill cast aluminum rear swingarm
• Fuel injection with motor-driven secondary throttle valves
• Four-into-one exhaust with EXUP
• 43mm inverted front fork w/left-leg compression damping
adjustment, right-leg rebound adjustment
• Dual 320mm front discs with four-piston calipers
• Shift Red; Silver
