Coolant chemistry is one of the most misunderstood and misinformed topics in motorsports. Probably because the average USA citizen hates chemistry, and either did poorly in chemistry class or never took any chemistry classes.
Engine Ice (propylene glycol) won't hurt the radiator.
Engine Ice does NOT cool as good as "normal" coolant (ethylene glycol + water)
The boiling point of engine ice is higher than normal anti-freeze.
The bottom line?
- Use Engine Ice on the race track and drag strip. You don't want to be THAT GUY who pukes slippery antifreeze and shuts down the entire track.
- Don't use Engine Ice if you don't track or drag, and your bike doesn't over heat. Normal antifreeze will allow your bike to run cooler and make more power.
Since Engine Ice has a higher boiling point, it works well in bikes that overheat - but that's just a Band-Aide! It's a lot better to get the dang overheating issue fixed!
If you want ultimate cool-running and best power output, run pure distilled water + water-wetter +about 20% ethylene glycol. The bike would actually run cooler with no ethylene glycol but it's needed for lubrication of the water pump and corrosion control. DON'T FORGET TO CHANGE IT OUT IF THE AIR TEMPERATURE GETS COOLER THAN ABOUT 16 DEGREES F or you'll risk cracking your motor and radiator wide open!!!
