I find it interesting that motorcycles generally lag (far) behind cars where the inlfux of technical advances is concerned.
For example, electronic sequential shifting is becoming increasingly commong in cars, while bikes are still using the clutch & foot lever method. Aftermarket ignition cut-out "quick shifters" are close, but not the full monty, since the user must manually actuate the clutch during downshifts. A true, full-on system would enable true up- & downshifting w/ the press of a button/pull of a trigger. A system I envisioned while doing research on my presentation in embedded systems would have opposing triggers for the forefinger (upshift) & thumb (downshift) to enable intuitive shifting while avoiding any chance of hitting the wrong switch. Such a system would use an ASIC or COTS CPU-based system that would incorporate embedded microcode to monitor gear selection relative to engine RPM & any other relavent factors to prohibit shifting if the selected gear is incompatible for the current monitored conditions (especially important when downshifting).
Another area concerns wheelspin control mechanisms. A tunable anti-spin system would be tailorable to suit rider preferences. Unlike digital ignition cutoff, which tends to be more abrupt, it would be linked to a digitally-controlled fuel pump to enable analog modulation of the wheelspin control.
There are a host of other things I could mention, but I find it interesting that it took at least a decade for EFI to make its way onto bikes. Part of the problem is that bikes are so much smaller than cars, so the technology isn't as easily or readily adaptable. The 2 things I've already mentioned here seem ready for prime time, but no one is putting in the effort.
Any thoughts or opinions on this?
