I bought a front wheel with rotors off of e-bay to use for a track-only wheel/tire set-up. I put a new tire on it tonight, and took it for a test ride… big problem – I have hardly any front brakes. The lever squeezes down very far. When I am stopped, I am able to pump them up, when moving there’s not much there. After the quick 2-mile test ride I looked everything over and noticed from the fresh wear marks on both rotors that my pads are only touching at the outside & inside edges (all four sides). It’s like the rotors are concave, or my pads are concave. It would seem like my pads could wear to match the contour of the rotors after a few hundred miles and a bunch of brake applications, but that would unnecessarily wear out the pads, and I need them to work for the other set-up as well. Plus, I wouldn’t have much braking available in the mean time.
What the hell is going on? I didn’t feel any pulsations while riding, so I don’t think that they are warped. Although, I did spin it before installing it and noticed a very slight wobble compared to my stock rotors & wheel. Do the new rotors need to be turned? Does anyone do that with motorcycle rotors, or are they too thin? The new ones are off of an R6, and actually have less wear (more thickness) than my stock ones.
I am leaving to go to Road America on Saturday, and then planned on using it on the track on Tuesday & Wednesday. Please help! What should I do? Use my original rotors on the new wheel? That was the reason that I bought a wheel with rotors, so I wouldn’t have to do that.
