Greetings,
I've just bought LighTech Limited Edition Rearset for my 2012 R1. The one on the pic below:
I've just installed the sets but I had some problems on the brake side. I also would like to mention that I use the bike mostly on road. The kit doesn't include any springs. Is any of the aftermarket rearsets include the return spring as in the OEM one? Using the sets without a spring doesn't feel safe to me..
I also purhased this brake light switch but I realize that it's logic is different than the OEM one:
Is it going to be used as a bolt for the rear master cylinder? Right? So to solve this problem and the spring problem at the same time I've used the OEM brake light switch on the LighTech rearsets.
But this configuration looks so bad and I don't like it... :cryin As a result I'm not happy with it.... Is all the aftermarket rearsets have the same spring and switch problem? I want to have a rear set which has original springs attached and has a place to attach the sensor of brake light :secret: Any brands?
Thanks
Thanks
