I ordered a front and rear sprocket from vortex. im second guessing putting it on because its aluminum and im concerened about it wearing out quick. has anyone used it and can give me some advice.
I have the older style Drive Systems black ano aluminum rear sprocket on my 02 :sneakyThese look pretty trick, anyone got any info :dunno
http://kurveygirl.com/shop/product_info.php?cPath=118_124&products_id=342
That's malarkey. Explain to me how a steel 520 setup is going to last longer than a steel 530 setup. There's physically less material in a 520 compared to a 530.You can now get high quality 520 lightweight steel sprockets and teamed up with strong 520 chains like the ek mvxz or ek zzz they will last longer then many 530 chain kits and be less weight and cost less...
+1 lube and adjust. Changing all the sprockets and chain together helps a lot too.Maintenance is key
