Resetting Check Engine Light
9.7K views 12 replies 6 participants last post by  Rachel Ayers
I just got the ECU Flashed on my 2023 R1. It’s all buttoned up and ready to go but I’m still waiting on a OBD2 to 6 pin Euro 5 adapter from Amazon to reset the check engine light with a scanner. For some reason the original OBD2 Euro 5 cable I ordered didn’t fit so I have order a different one.
I’m locked into A Mode. Can I ride a several miles and on/off cycle a couple times to reset the check engine light? I read you can do this on 2019 and prior R1’s but I wasn’t sure about the lastest 2020 and newer iteration? Figure I’d ask first and I could try while waiting for the adapter.
#2 · (Edited)
Instructions:
Watch video
then read comments
EDIT: Opps, think this doesnt work on 2020 and up.. Basically you press the mode button and the up button (right above the mode button) and turn key on and do it two more times to get to diagnostic mode. Then press up or down to get to 62, then on the right handle bar press on/off switch to on, then to off. That procedure works on my 2016 R1M.
#3 · (Edited)
Instructions:
Watch video
then read comments
I appreciate it. Unfortunately no diagnostic mode on the 2020-2024 R1’s. We have to use an OBD2 six pin cable and reset with a scanner. I’ve heard you can run for several miles and run two on/off cycles but sometimes it really does require a scanner reset.
This will work, I have this for my 22. It's not bad to have and fairly cheap.
Amazon.com: Autel Professional OBD2 Scanner AL319 Code Reader, Enhanced Check and Reset Engine Fault Code, Live Data, Freeze Frame, CAN Car Diagnostic Scan Tools for All OBDII Vehicles After 1996, 2024 Upgraded : Automotive
Buy Autel Professional OBD2 Scanner AL319 Code Reader, Enhanced Check and Reset Engine Fault Code, Live Data, Freeze Frame, CAN Car Diagnostic Scan Tools for All OBDII Vehicles After 1996, 2024 Upgraded: Code Readers & Scan Tools - Amazon.com ✓ FREE DELIVERY possible on eligible purchases
www.amazon.com
Amazon.com: AUGREX OBD2 Adapter Cable for Moto Guzzi Piaggio Vespa Milan Yamaha Harley Davidson and More, 6 Pin Motorcycle Wiring Adapter Plug Cable : Automotive
Buy AUGREX OBD2 Adapter Cable for Moto Guzzi Piaggio Vespa Milan Yamaha Harley Davidson and More, 6 Pin Motorcycle Wiring Adapter Plug Cable: Code Readers & Scan Tools - Amazon.com ✓ FREE DELIVERY possible on eligible purchases
www.amazon.com
I appretiate it. I have a scanner and I ordered the cable. It’s on the way. I was able to reset but running the bike a few miles and a couple on off key cycles. That took care of the post ECU flash check engine light. I’ll hold on to the scanner though because I’m sure it’ll come in handy in the future.
