Can someone explain the deal with 520 vs 530 sprockets. What does the 520 stand for? Am I correct in understanding that the 520 is just a lighter weight construction for the sprockets and chain and that this saves weight on the bike at the expense of quicker wear? Or is there more going on.
I'm thinking about dropping the front sprocket on my 2005 R1 down one tooth. I'm not sure if I want to stay with the stock 530 (whatever that means
stuff or switch the entire stuff over to 520.
I was thinking I might try one of those Supersprox things I see advertised in magazines. Does anyone have any experience with those and/or could they recommend other sprockets that are light, but just as strong. The Supersprox's say 300% longer life than aluminum. I like the idea of sticking with a D.I.D. chain.
Any insight would be welcome.
Also, in order to remove and re-install the front sprocket, is there any trick to it to avoid spinning the motor or how do you guys go about that? I have an impact wrench, but I don't want to damage anything while swapping the front sprocket. Is there an approved method for blocking movement of it while getting that huge ass bolt on/off
Ray
Ray
