I'm having starting issues. Every time it's cold, my bike struggles to start. Sometimes the battery dies after trying to start it. I have two batteries, and it's happened to both. Are my batteries bad, or could there be an issue with the bike?
Hey guys I"m on my 3rd R1, yes 3rd....1st was an 05, then 2 diff 06's and had the same exact same problems on EVERY ONE...If this wasn't the sexiest bike ever made I would have never bought another one...had them in the shop several times to no avail...had starters rebuilt, changed ecu's, bought several batteries,still same prob...if the battery and charging system checks out, IT'S NOT THE BATTERY...well it may be if you buy them cheap ass chinese ones....yuusa are great....with my current 06 R1 it sounds like the batt is dead but def is not, I just hold the starter button down till it eventually starts....or I crank it for a few seconds, if it does not start i wait 20 seconds try again...it will eventually start but sometimes takes a few tries...its something with the starter not getting enough amps...remember I've had 2 diff starters cleaned and rebuilt and had the same exact prob afterwards with a new battery...my sugestion is to try and get a dry cel or a batt with a few more cca's or try what this guy did which is a great idea instead of pulling out the starter which is NOT fun....~~~~~~> So this is what I did. I took the tank off and made sure the battery was fully charged. I cleaned and inspected all the connectors on the bike to make sure it wasn?t something as simple as a burnt connector. With the tank off, I held down the starter button till the battery drained. Then I charged up the battery again. I kept doing this till the starter started to run freely. I did this about 6-10 times. It started off like that battery wasn?t strong enough to run the starter, but by the end, the starter was running really strong. I put everything back on the bike, and now it fires up easily. The start seems stronger than it did when I first bought my bike brand new. Now it doesn?t drain the battery. I wanna take the starter out and completely clean it now that I know the problem was the starter. I know some people might say that this might mess up your bike, but I?m on a budget, and don?t have a lot of tools. I?m just glad that after dealing with this for over a year, my R1 is back to being reliable again.
