I put stomp grips on my '01 with OK, but not great, results. Kinda a pain in the azz making my own pattern and then cutting to fit since nobody sells pre-cut grips for models older than '02. Or at least Stomp Grip doesn't. The Tech Specs said there are patterns available for other bikes, but I'm not going to get my hopes up. Anyway, my experience with the Stomp Grips is like this: they're great function-wise in that you're not going to slide around at all, especially while braking. The bad? Well, even after prepping (cleaning with alcohol) the shiat outta the tank, using a hairdrier to warm the grip and tank, the grip still wants to peel off around the edges. Working the bubbles out was a pain also. Thinking about ripping them off and either doing over again or trying Tech Specs. After reading nomad's post, I might just try calling Stomp Grips and see about getting them replaced.
